48-1263 fibreboard backing
Cheap particle board furniture, such as a bookcase would have a fiberboard back that would work. You might even get lucky and find one that someone has set out in the trash.
M R Radios   C M Tubes
48-1263 fibreboard backing - by lasurveyor - 09-23-2012, 12:00 PM
RE: 48-1263 fibreboard backing - by codefox1 - 09-23-2012, 02:21 PM
RE: 48-1263 fibreboard backing - by lasurveyor - 09-23-2012, 11:33 PM
RE: 48-1263 fibreboard backing - by Marsupial - 09-24-2012, 07:34 AM
RE: 48-1263 fibreboard backing - by codefox1 - 09-24-2012, 05:49 PM
RE: 48-1263 fibreboard backing - by Steve Davis - 09-24-2012, 06:33 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1504 online users. [Complete List]
» 3 Member(s) | 1501 Guest(s)
