Coronado/Wells gardner
Well,I finished up the Coronado with the Wells Gardner model 2CM radio.
Has 12 tubes and 2, 12 inch speakers.
Fairly easy chassis to work on, and well built.
Sounds as good as it looks.
[Image: http://i1161.photobucket.com/albums/q509..._wg2cm.jpg]
Coronado/Wells gardner - by murf - 09-24-2012, 09:19 PM
RE: Coronado/Wells gardner - by TA Forbes - 09-24-2012, 10:01 PM
RE: Coronado/Wells gardner - by Gene Pederson - 09-24-2012, 11:36 PM
RE: Coronado/Wells gardner - by Michael Dennis - 09-25-2012, 08:01 AM
RE: Coronado/Wells gardner - by Arran - 09-25-2012, 07:46 PM
RE: Coronado/Wells gardner - by murf - 10-27-2012, 02:47 PM
RE: Coronado/Wells gardner - by TA Forbes - 10-27-2012, 04:31 PM
There are currently 8017 online users. [Complete List]
» 1 Member(s) | 8016 Guest(s)
