Philco 41-265 Output Transformer 32-8116N
I am restoring a 41-265 console and I have a defective OPT with a shorted primary to secondary (all leads disconnected). The Hammond 125ASE looks like a likely replacement being 2500-10K primary with a 4 ohm connected secondary and physically is almost the same size as original. Is this a good choice for a single ended type 41 tube or is there a better choice?
Philco 41-265 Output Transformer 32-8116N - by Dan Metro - 09-27-2012, 12:53 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 4017 online users. [Complete List]
» 2 Member(s) | 4015 Guest(s)
