New project: 1936 model 630
Just picked up a nice example of this set. It *seems* in fairly good shape, but, as we all know, looks can be deceiving. I was told it works and receives stations, but (again) we've all heard that one before! It has a new (and newer style) cord on it, so someone was at least doing some kind of work to it fairly recent. I'm going to take the chassis out of the cabinet and give it the once over before I even think about applying power to it. If it's not already recapped, that will be the first order of business.
For now, I have a VERY basic (and probably dumb) question:
What are the functions of the three knobs, going from left to right (I know the top one is tuning)?
I literally just received the set today, so I haven't done anything to it. But knowing the functions of the switches will be a helpful place to start!
Thanks Icon_biggrin
New project: 1936 model 630 - by NostalgiaRadioTime - 09-28-2012, 09:44 PM
RE: New project: 1936 model 630 - by TA Forbes - 09-28-2012, 09:52 PM
RE: New project: 1936 model 630 - by Ron Ramirez - 09-28-2012, 10:20 PM
Philco 91 Tuning Condenser
There are currently 5350 online users. [Complete List]
» 1 Member(s) | 5349 Guest(s)
