Model 97B Tombstone
It would not be a 118 if it has four bands. It might possibly be a 640 or a 650, I'm not that familiar with the 6xx Philcos. At any rate, you better get back there and grab it before someone else does.
M R Radios   C M Tubes
Model 97B Tombstone - by Gene Pederson - 10-01-2012, 09:59 AM
RE: Which Model Tombstone is This? - by TA Forbes - 10-01-2012, 12:08 PM
RE: Which Model Tombstone is This? - by Steve Davis - 10-01-2012, 01:07 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-02-2012, 08:07 PM
RE: Model 97B Tombstone - by Steve Davis - 10-02-2012, 09:08 PM
RE: Model 97B Tombstone - by TA Forbes - 10-02-2012, 11:14 PM
RE: Model 97B Tombstone - by Ron Ramirez - 10-03-2012, 05:37 AM
RE: Model 97B Tombstone - by Gene Pederson - 10-03-2012, 10:01 AM
RE: Model 97B Tombstone - by Arran - 10-04-2012, 06:26 PM
RE: Model 97B Tombstone - by Ron Ramirez - 10-04-2012, 07:39 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-05-2012, 12:16 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-05-2012, 12:24 PM
Philco 91 Tuning Condenser
There are currently 5936 online users. [Complete List]
» 2 Member(s) | 5934 Guest(s)
