Trouble getting started
Hi guys,
I found 2 bad tubes: 14B6, 50A5. I'll let you know after the replacements arrive.
Eric
Eric
The Villages, FL
Trouble getting started - by Eric Adams - 09-17-2012, 03:57 PM
RE: Trouble getting started - by Arran - 09-17-2012, 05:43 PM
RE: Trouble getting started - by Eric Adams - 09-17-2012, 06:07 PM
RE: Trouble getting started - by jerryhawthorne - 09-17-2012, 08:38 PM
RE: Trouble getting started - by Paul Philco322 - 09-17-2012, 08:52 PM
RE: Trouble getting started - by Eric Adams - 09-17-2012, 09:09 PM
RE: Trouble getting started - by Arran - 09-17-2012, 09:48 PM
RE: Trouble getting started - by jerryhawthorne - 09-30-2012, 12:48 AM
RE: Trouble getting started - by Eric Adams - 09-30-2012, 01:05 AM
RE: Trouble getting started - by jerryhawthorne - 09-30-2012, 03:00 AM
RE: Trouble getting started - by Eric Adams - 09-30-2012, 12:35 PM
RE: Trouble getting started - by Arran - 09-30-2012, 07:56 PM
RE: Trouble getting started - by Eric Adams - 09-30-2012, 11:00 PM
RE: Trouble getting started - by Arran - 09-30-2012, 11:57 PM
RE: Trouble getting started - by Eric Adams - 10-01-2012, 12:23 AM
RE: Trouble getting started - by Eric Adams - 10-01-2012, 07:41 PM
Philco 91 Tuning Condenser
