660 Chassis into 640 or 650 cabinet
Hi Pete
No, it will not. The 660 chassis is physically larger than the 640 and 650 chassis. In fact the 660 chassis is the same size as a 116 chassis.
660 Chassis into 640 or 650 cabinet - by AI2V - 06-17-2007, 10:46 AM
[No subject] - by Ron Ramirez - 06-17-2007, 11:12 AM
660/650 Chassis sizes - by AI2V - 06-17-2007, 02:02 PM
[No subject] - by Ron Ramirez - 06-17-2007, 09:36 PM
