Iveyline Radio from Hickory, NC
Still trying to figure it out. I don't think the tube complement is right, the UX199 and x171 seem out of place before the Daven three tube amplifier.
I am thinking that 01As should go there. But I am not real spun up on these older 20s sets, so I want to figure everything out before I plunge madly ahead.
Iveyline Radio from Hickory, NC - by TA Forbes - 10-02-2012, 04:23 AM
RE: Iveyline Radio from Hickory, NC - by ipwizard - 10-02-2012, 11:45 AM
RE: Iveyline Radio from Hickory, NC - by TA Forbes - 10-02-2012, 04:10 PM
RE: Iveyline Radio from Hickory, NC - by Arran - 10-03-2012, 12:31 AM
There are currently 11437 online users. [Complete List]
» 2 Member(s) | 11435 Guest(s)
