37-675X De Luxe
I guess it would depend on how high the price is. Check the hole in the grill cloth to make sure there isn't a matching hole in the speaker like I usually run into. I have one of these consoles myself and I think I paid roughly $150 just to get it without knowing what I had until I got it home. The off-on/tone control on mine is really messed up, but when it is behaving this radio will bury a 12 tube Zenith from the same era.
37-675X De Luxe - by LASJayhawk - 10-02-2012, 10:00 PM
RE: 37-675X De Luxe - by Jayce - 10-02-2012, 10:23 PM
RE: 37-675X De Luxe - by TA Forbes - 10-02-2012, 11:10 PM
RE: 37-675X De Luxe - by Doug Houston - 10-02-2012, 11:55 PM
RE: 37-675X De Luxe - by Arran - 10-03-2012, 01:23 AM
Philco 91 Tuning Condenser
There are currently 5896 online users. [Complete List]
» 1 Member(s) | 5895 Guest(s)
