  • 2 Vote(s) - 2.5 Average
Philco 40-140 Field Coil Replacement
Thanks, Jerry. Well, I'll bench test this one and if I notice any hum, I may have to increase that small electrolytic cap a bit. I think it's only a 4uf.
Philco 40-140 Field Coil Replacement - by radiola - 09-05-2012, 12:21 AM
RE: Philco 40-140 Field Coil Replacement - by radiola - 10-02-2012, 11:01 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 2891 online users. [Complete List]
» 3 Member(s) | 2888 Guest(s)
