Model 97B Tombstone
Gene
Great score! Icon_thumbup
I think I have an extra dial I made when I built my reproduction 97 - it's a heavily modified 118 chassis with a 620 front end, so mine has 8 tubes instead of 7. Anyway, you're welcome to the scale if I can find it, but bear in mind I did not have an original to go by so it will not look original. It looks like a 620/630 scale but it will fit perfectly. The 97 has the same frequency coverage as the 620/630. Send me a PM if interested.
Model 97B Tombstone - by Gene Pederson - 10-01-2012, 09:59 AM
RE: Which Model Tombstone is This? - by TA Forbes - 10-01-2012, 12:08 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-02-2012, 08:07 PM
RE: Model 97B Tombstone - by Steve Davis - 10-02-2012, 09:08 PM
RE: Model 97B Tombstone - by TA Forbes - 10-02-2012, 11:14 PM
RE: Model 97B Tombstone - by Ron Ramirez - 10-03-2012, 05:37 AM
RE: Model 97B Tombstone - by Gene Pederson - 10-03-2012, 10:01 AM
RE: Model 97B Tombstone - by Arran - 10-04-2012, 06:26 PM
RE: Model 97B Tombstone - by Ron Ramirez - 10-04-2012, 07:39 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-05-2012, 12:16 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-05-2012, 12:24 PM
Philco 91 Tuning Condenser
There are currently 5361 online users. [Complete List]
» 1 Member(s) | 5360 Guest(s)
