It's a seven tube AM/FM set, with phonograph, as is I wouldn't pay anymore then $15-30 on a good day, in decent condition with a good original finish. I think that it may be a transformerless design with a voltage doubler as the gallery says it has two selenium rectifiers. Although it probably is not a bad radio it has little collectable value, they take up too much space, and it's very seldom that one of these does not have a dead Rochelle salt phonograph cartridge.
49-1606 - by morzh - 10-03-2012, 10:29 AM
RE: 49-1606 - by rghines1 - 10-04-2012, 01:27 PM
RE: 49-1606 - by morzh - 10-04-2012, 05:59 PM
RE: 49-1606 - by Arran - 10-04-2012, 07:24 PM
RE: 49-1606 - by morzh - 10-04-2012, 07:55 PM
The speaker table error?
Philco 70 antenna lead
