Model 97B Tombstone
TA Forbes,
The dial is dark brown. There is a hint of red in it, but I don't know what color it originally was due to the age.
Gene
Model 97B Tombstone - by Gene Pederson - 10-01-2012, 09:59 AM
RE: Which Model Tombstone is This? - by TA Forbes - 10-01-2012, 12:08 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-02-2012, 08:07 PM
RE: Model 97B Tombstone - by Steve Davis - 10-02-2012, 09:08 PM
RE: Model 97B Tombstone - by TA Forbes - 10-02-2012, 11:14 PM
RE: Model 97B Tombstone - by Ron Ramirez - 10-03-2012, 05:37 AM
RE: Model 97B Tombstone - by Gene Pederson - 10-03-2012, 10:01 AM
RE: Model 97B Tombstone - by Arran - 10-04-2012, 06:26 PM
RE: Model 97B Tombstone - by Ron Ramirez - 10-04-2012, 07:39 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-05-2012, 12:16 PM
RE: Model 97B Tombstone - by Gene Pederson - 10-05-2012, 12:24 PM
Philco 91 Tuning Condenser
There are currently 3945 online users. [Complete List]
» 1 Member(s) | 3944 Guest(s)
