philco model 29
Great info guy's,
Without getting too technical, I want to get the electrolitics and wire them into the correct components.
With having the original components basturdized, I am looking for an easy way to wire in the new ones.
The schematics are not making alot of sense to me if I can't relate them back to the chassis, due to someones shortcuts.
I will try taking Aaran's verbal description and using my highlighter, I will try to trace everything back to where it belongs.
Be patient please as I am still learning.
philco model 29 - by murf - 10-04-2012, 10:20 PM
RE: philco model 29 - by Arran - 10-05-2012, 12:22 AM
RE: philco model 29 - by Ron Ramirez - 10-05-2012, 05:41 AM
RE: philco model 29 - by murf - 10-05-2012, 06:58 AM
RE: philco model 29 - by Glenn Roberts - 10-05-2012, 10:31 AM
RE: philco model 29 - by TA Forbes - 10-05-2012, 01:25 PM
RE: philco model 29 - by murf - 10-05-2012, 08:53 PM
RE: philco model 29 - by Ron Ramirez - 10-05-2012, 09:13 PM
RE: philco model 29 - by Steve Davis - 10-05-2012, 09:22 PM
RE: philco model 29 - by Arran - 10-05-2012, 10:01 PM
RE: philco model 29 - by murf - 10-13-2012, 03:47 PM
RE: philco model 29 - by murf - 10-13-2012, 03:55 PM
RE: philco model 29 - by Arran - 10-14-2012, 12:18 AM
RE: philco model 29 - by murf - 10-14-2012, 09:00 AM
The speaker table error?
Philco 70 antenna lead
