philco model 29
"It is important to consider that the larger the electrolytic value in microfarads, the larger hit your rectifier will take until the caps are fully charged. ONCE charged, however, no difference."
Actually, the rectifier will take a hit once every cycle. Think of it as butting your head against a wall 120 times a second. Would you rather the wall be padded or bare concrete?Icon_biggrin
M R Radios   C M Tubes
philco model 29 - by murf - 10-04-2012, 10:20 PM
RE: philco model 29 - by Arran - 10-05-2012, 12:22 AM
RE: philco model 29 - by Ron Ramirez - 10-05-2012, 05:41 AM
RE: philco model 29 - by murf - 10-05-2012, 06:58 AM
RE: philco model 29 - by Glenn Roberts - 10-05-2012, 10:31 AM
RE: philco model 29 - by TA Forbes - 10-05-2012, 01:25 PM
RE: philco model 29 - by murf - 10-05-2012, 08:53 PM
RE: philco model 29 - by Ron Ramirez - 10-05-2012, 09:13 PM
RE: philco model 29 - by Steve Davis - 10-05-2012, 09:22 PM
RE: philco model 29 - by Arran - 10-05-2012, 10:01 PM
RE: philco model 29 - by murf - 10-13-2012, 03:47 PM
RE: philco model 29 - by murf - 10-13-2012, 03:55 PM
RE: philco model 29 - by Arran - 10-14-2012, 12:18 AM
RE: philco model 29 - by murf - 10-14-2012, 09:00 AM
The speaker table error?
Philco 70 antenna lead
