Freshly restored 47-205
Thanks. I think it's some kind of particle board with the "leatherette" look pressed into it. I forgot I also had to install a new bulb for the dial light Icon_e_biggrin
Since the original plastic dial "glass" was so badly yellowed and cloudy (see pic), I made a new one out of a piece of 3/16" thick plexiglass. It's not convex like the original , but I made it a nice tight press fit, and positioned it far enough ahead to allow for the dial pointer to clear it. I think it looks decent.
Freshly restored 47-205 - by NostalgiaRadioTime - 10-07-2012, 09:34 PM
RE: Freshly restored 47-205 - by Paul Philco322 - 10-08-2012, 11:29 AM
RE: Freshly restored 47-205 - by NostalgiaRadioTime - 10-08-2012, 07:29 PM
RE: Freshly restored 47-205 - by TA Forbes - 10-08-2012, 10:48 PM
Philco 91 Tuning Condenser
There are currently 3527 online users. [Complete List]
» 1 Member(s) | 3526 Guest(s)
