Molded paper capacitors
I believe what you could have is a moulded resistor, which Philco did use in early models. I do not believe Philco used micamold paper caps.
See here: MOULDED WIRE-WOUND RESISTORS
USED IN OLDER MODELS FROM 1936 TO 1940s
Check the schematic to be sure of the part in question.
Molded paper capacitors - by Raleigh - 06-20-2007, 01:24 PM
[No subject] - by Chuck Schwark - 06-20-2007, 01:40 PM
[No subject] - by Raleigh - 06-20-2007, 01:56 PM
[No subject] - by Raleigh - 06-20-2007, 11:50 PM
[No subject] - by Poston Drake - 07-02-2007, 10:16 PM
