  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
#43
Henry was an All American heavyweight wrestler. He is one of those fellows with a very large frame. Shaking his hand is like shaking hands with a bowling ball.
He coaches now and has had three of his former HS wrestlers go to the Olympics. Tervel Dlagnev, who finished 5th in the Olympics in the 120Kg (242lb) class last summer, was one of Henry's former students.
RE: Philco 37-116X What's The Price Point? - by TA Forbes - 10-08-2012, 10:43 PM
Users browsing this thread: 13 Guest(s)
Philco 91 Tuning Condenser
There are currently 4398 online users. [Complete List]
» 1 Member(s) | 4397 Guest(s)
