Another new Philco today 38-2xx
Bought this today as a package deal with my Radio Bar, Needs some TLC but in overall decent condition.
Rock
Another new Philco today 38-2xx - by rocklandman - 10-09-2012, 07:53 PM
RE: Another new Philco today 38-2xx - by Jayce - 10-09-2012, 08:04 PM
RE: Another new Philco today 38-2xx - by Jayce - 10-09-2012, 09:31 PM
RE: Another new Philco today 38-2xx - by Geoff - 10-12-2012, 06:22 PM
Philco 91 Tuning Condenser
