Low volume
Spend the dollar or so to replace the rest of the ancient resistors. You can get a good enough digital frequency meter for very little nowadays. Old signal generators can get quite cranky. Mine was off by more than 10 KZ before I checked.
Best of luck.
Low volume - by jph14 - 10-11-2012, 08:07 AM
RE: Low volume - by rghines1 - 10-11-2012, 12:40 PM
RE: Low volume - by Chuck Schwark - 10-11-2012, 01:55 PM
RE: Low volume - by jph14 - 10-11-2012, 04:25 PM
RE: Low volume - by codefox1 - 10-11-2012, 07:00 PM
RE: Low volume - by jph14 - 10-12-2012, 03:08 PM
RE: Low volume - by codefox1 - 10-12-2012, 06:59 PM
RE: Low volume - by jph14 - 10-14-2012, 05:28 PM
The speaker table error?
Philco 70 antenna lead
