Gearing up to work on a 16b
"Whiskey" is the color of what is commonly referred to as the 70/90 pattern, since it is the same cloth used in Model 70 and 90 cathedral sets.
There was also a copper variation of the same pattern, used in models 19, 89, and a few other 1933 Philco cathedrals although I think the 16B used the whiskey color cloth.
Good luck finding any. I think there was a vendor selling some leftover cloth at Kutztown, but it's all going to become impossible to find sooner rather than later.
Gearing up to work on a 16b - by LedHed - 10-12-2012, 01:30 AM
RE: Gearing up to work on a 16b - by ipwizard - 10-12-2012, 02:18 AM
RE: Gearing up to work on a 16b - by TA Forbes - 10-12-2012, 04:27 AM
RE: Gearing up to work on a 16b - by Ron Ramirez - 10-12-2012, 05:19 AM
RE: Gearing up to work on a 16b - by LedHed - 10-12-2012, 08:49 AM
Philco 91 Tuning Condenser
There are currently 5802 online users. [Complete List]
» 3 Member(s) | 5799 Guest(s)
