Gearing up to work on a 16b
Thanks for the speedy responses everyone. It sounds like I'm going to just find something kinda close that I like. Other than the European fellow's website and EvilPay are there any other known suppliers? I found one guy on the Alternative Radio Forum that had some cloth for sale, but it just isn't right.
Gearing up to work on a 16b - by LedHed - 10-12-2012, 01:30 AM
RE: Gearing up to work on a 16b - by ipwizard - 10-12-2012, 02:18 AM
RE: Gearing up to work on a 16b - by TA Forbes - 10-12-2012, 04:27 AM
RE: Gearing up to work on a 16b - by Ron Ramirez - 10-12-2012, 05:19 AM
RE: Gearing up to work on a 16b - by LedHed - 10-12-2012, 08:49 AM
Philco 91 Tuning Condenser
