Need Help to ID this Philco Tombstone?
Hello all,
I got this today at an estate sale,
No label?
the radio looks like a 5 tube
25z5, 43, the others are in the tube sheilds and I don't want to start pulling out as of yet.
there is no transformer but the plug on the end does seem like a regular wall outlet plug.
"Don't worry i'm not plugging it in!!"
Thanks
Rock
Need Help to ID this Philco Tombstone? - by rocklandman - 10-12-2012, 02:17 PM
Philco 91 Tuning Condenser
There are currently 5371 online users. [Complete List]
» 1 Member(s) | 5370 Guest(s)
