Need Help to ID this Philco Tombstone?
5 tubes, I think, would make it a 611B.
Mike
RE: Need Help to ID this Philco Tombstone? - by Michael Dennis - 10-12-2012, 03:46 PM
Philco 91 Tuning Condenser
There are currently 5760 online users. [Complete List]
» 4 Member(s) | 5756 Guest(s)
AvatarAvatarAvatarAvatar
