Philco 40-180 antennae wire?
Hi Diyahnih
For starters - since you have two wires protruding from a place near the power transformer - PROCEED WITH CAUTION.
Model 40-180 has a built-in loop antenna, which is shaped like a long oval tube. It needs no external antenna, even though there is a provision for one.
You really should find out what those wires are - with the set unplugged, of course - and where they come from. They should not be there.
Philco 40-180 antennae wire? - by diyahnih - 06-23-2007, 02:48 PM
[No subject] - by Ron Ramirez - 06-24-2007, 12:22 AM
re: 40-180 wires - by diyahnih - 06-25-2007, 07:03 PM
