And, finally...a Scott Philharmonic!
Ron, what a great find. Looking forward to the receiver pictures as well. Love to see it after a little dusting. Don't know how you have the time for this stuff. Looks like the chrome should clean up well. If you don't like it, send it out here!
Jerry
RE: And, finally...a Scott Philharmonic! - by jerryhawthorne - 10-13-2012, 12:27 AM
There are currently 10523 online users. [Complete List]
» 1 Member(s) | 10522 Guest(s)
