And, finally...a Scott Philharmonic!
Very nice find Mr Scott, 'er, I mean Ron.
I like the extra nice touch on the serial number plate lettering. meant to be.
Bruce
RE: And, finally...a Scott Philharmonic! - by y2kbruce - 10-13-2012, 07:35 AM
There are currently 9069 online users. [Complete List]
» 5 Member(s) | 9064 Guest(s)
AvatarAvatarAvatarAvatar
