PHILCO 98 EXPORT Model
Hi again folks.
Sorry about the delay. Computor had to be cleaned of a trojanjh.
Photos attached.
[Image: http://i326.photobucket.com/albums/k420/...f/98-1.jpg]
[Image: http://i326.photobucket.com/albums/k420/...f/98-3.jpg]
your thaughts are very welcome.
regards.
hotwire
PHILCO 98 EXPORT Model - by HOTWIRE - 10-08-2012, 01:50 PM
RE: PHILCO 98 EXPORT Model - by TA Forbes - 10-08-2012, 10:33 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-13-2012, 09:44 AM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-13-2012, 09:53 AM
RE: PHILCO 98 EXPORT Model - by TA Forbes - 10-14-2012, 08:55 AM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 10-14-2012, 09:17 AM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 10-14-2012, 11:01 AM
RE: PHILCO 98 EXPORT Model - by TA Forbes - 10-14-2012, 09:26 PM
RE: PHILCO 98 EXPORT Model - by Arran - 10-14-2012, 11:02 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-15-2012, 03:18 PM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 10-15-2012, 04:23 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 10-15-2012, 07:18 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 03-12-2013, 11:27 AM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 03-15-2013, 02:04 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 03-15-2013, 11:14 PM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 03-17-2013, 01:08 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 03-19-2013, 09:09 AM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 06:02 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 06:06 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 06:13 PM
RE: PHILCO 98 EXPORT Model - by Ron Ramirez - 09-09-2014, 06:47 PM
RE: PHILCO 98 EXPORT Model - by HOTWIRE - 09-09-2014, 08:19 PM
There are currently 7887 online users. [Complete List]
» 3 Member(s) | 7884 Guest(s)
