A Phalse Philco
[Image: http://www.wa2ise.com/radios/ph124k.jpg]
Found this at a Kmart 15 years ago, seem some Chinese company licensed the Philco name.
A Phalse Philco - by wa2ise - 10-14-2012, 05:37 PM
RE: A Phalse Philco - by Chuck Schwark - 10-14-2012, 07:56 PM
RE: A Phalse Philco - by Ron Ramirez - 10-14-2012, 08:12 PM
RE: A Phalse Philco - by Chuck Schwark - 10-14-2012, 08:59 PM
RE: A Phalse Philco - by flemiglee - 12-26-2012, 10:13 AM
Philco 91 Tuning Condenser
