Mohawk finishing products for Philco 47-1230
No Blush is Great stuff!!!!
It's like magic. Have used it in the Mohawk class and on stuff I've done later. Would definitely recommend getting a can or two. It can really help with removing the milky haze from too much humidity.
RE: Mohawk finishing products for Philco 47-1230 - by 7estatdef - 10-17-2012, 08:41 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1269 online users. [Complete List]
» 3 Member(s) | 1266 Guest(s)
