Turntable reflocking
At work I sometimes have to repair a small burn in a volure car seat. For that we have many different colored fibers to match original,use a little spray glue and a small Van De Graff generator to make the fiber stand up on end.
Turntable reflocking - by NostalgiaRadioTime - 09-23-2012, 01:41 PM
RE: Turntable reflocking - by Sean - 09-24-2012, 08:44 AM
RE: Turntable reflocking - by NostalgiaRadioTime - 09-24-2012, 05:21 PM
RE: Turntable reflocking - by Marsupial - 09-24-2012, 06:28 PM
RE: Turntable reflocking - by NostalgiaRadioTime - 09-24-2012, 07:38 PM
RE: Turntable reflocking - by Arran - 09-24-2012, 08:39 PM
RE: Turntable reflocking - by 7estatdef - 10-17-2012, 08:48 AM
RE: Turntable reflocking - by jerryhawthorne - 11-10-2012, 07:00 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2472 online users. [Complete List]
» 4 Member(s) | 2468 Guest(s)
AvatarAvatarAvatarAvatar
