Antenna wire for 39-45
Used an outdoor antenna and ground, no built-in loop.
Chuck
Antenna wire for 39-45 - by mikesloane - 10-16-2012, 04:24 PM
RE: Antenna wire for 39-45 - by 7estatdef - 10-16-2012, 05:58 PM
RE: Antenna wire for 39-45 - by mikesloane - 10-16-2012, 06:09 PM
RE: Antenna wire for 39-45 - by LASJayhawk - 10-16-2012, 06:52 PM
RE: Antenna wire for 39-45 - by Chuck Schwark - 10-17-2012, 02:51 PM
RE: Antenna wire for 39-45 - by Eric T - 10-19-2012, 12:58 PM
RE: Antenna wire for 39-45 - by mikesloane - 10-19-2012, 01:26 PM
RE: Antenna wire for 39-45 - by LASJayhawk - 10-20-2012, 01:15 AM
RE: Antenna wire for 39-45 - by LASJayhawk - 10-20-2012, 01:19 AM
The speaker table error?
Philco 70 antenna lead
