Philco 20
What bulb was usually used and did the voltage come from the transfomer or the filaments of the 71a tubes?
Philco 20 - by Robert Miller - 06-27-2007, 09:28 AM
[No subject] - by Chuck Schwark - 06-27-2007, 09:48 AM
[No subject] - by Ron Ramirez - 06-28-2007, 09:25 PM
[No subject] - by Chuck Schwark - 06-29-2007, 09:46 AM
model 20 - by Robert Miller - 06-29-2007, 01:19 PM
[No subject] - by Chuck Schwark - 06-29-2007, 02:12 PM
pilot lamp - by Robert Miller - 06-29-2007, 02:32 PM
[No subject] - by Texasrocker - 06-29-2007, 11:36 PM
[No subject] - by ckc - 06-30-2007, 09:33 PM
