Truetone D724 power xformer replacement?
Point of failure is uncertain. If transformer and rectifier is still good go slow with the variac and monitor B+. Alternately you can remove rectifier and measure AC from each plate to center tap of HV winding, but be carefull Lots of Volts! They should be almost the same.
RE: Truetone D724 power xformer replacement? - by codefox1 - 10-18-2012, 11:28 PM
There are currently 10172 online users. [Complete List]
» 1 Member(s) | 10171 Guest(s)
