Model 65 Modulation Hum
Something else came to mind if you still can't find it check your RF coils for (green primaries) corrosion. You may have a sightly bad coil that isn't giving you a good ground return for the grid of the tube. Also you could have a bad 24 tube. It could have a short from the cathode to grid 1 or a heater to cathode. If you've got a spare I'd swap it and see if that does the trick. Either 24 could be at fault. The pilot lamp may affect the overall amount of hum. It may have a bit more of less with or without it in the circuit.
Just a thought.
Model 65 Modulation Hum - by Sourbone - 10-20-2012, 03:00 PM
RE: Model 65 Modulation Hum - by TA Forbes - 10-20-2012, 03:53 PM
RE: Model 65 Modulation Hum - by Sourbone - 10-20-2012, 04:17 PM
RE: Model 65 Modulation Hum - by LASJayhawk - 10-20-2012, 05:33 PM
RE: Model 65 Modulation Hum - by Sourbone - 10-20-2012, 05:53 PM
RE: Model 65 Modulation Hum - by 7estatdef - 10-20-2012, 07:00 PM
RE: Model 65 Modulation Hum - by Chuck Schwark - 10-20-2012, 10:30 PM
RE: Model 65 Modulation Hum - by Sourbone - 10-21-2012, 08:52 AM
RE: Model 65 Modulation Hum - by codefox1 - 10-21-2012, 10:06 AM
RE: Model 65 Modulation Hum - by 7estatdef - 10-21-2012, 01:52 PM
RE: Model 65 Modulation Hum - by peteivan - 11-02-2012, 09:29 PM
RE: Model 65 Modulation Hum - by codefox1 - 11-02-2012, 09:39 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
