Model 38-9
Marv, you can also "steal" a pin socket out of another socket to place in the #1 position in existing socket. Clean all solder from pin terminal, you will see a triangular protrusion on the pin terminal, squeeze it back in and push terminal down and out hole (working from under chassis, set up side down). Push pin into #1 hole in exsisting socket from top and bend out protrusion which holds it in place.
PL
Model 38-9 - by Guest - 06-25-2007, 08:47 PM
[No subject] - by Ron Ramirez - 06-28-2007, 09:32 PM
[No subject] - by planigan - 07-03-2007, 04:45 AM
