  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
I've found that the "Local" selection is all but useless. There is a station here in my city that I can hardly hear on the "Local" setting. In order to receive anything with any strength I need it set to "Distance".
- Geoff
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 10-21-2012, 09:38 PM
There are currently 2343 online users. [Complete List]
» 3 Member(s) | 2340 Guest(s)
