  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
You can replace that 47k resistor with a 12k and the local function works a lot better! Maybe a little higher value is you transmit AM though a sstran or whatever.
Did you make sure you replace the 1meg in the eye tube socket?
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by jth877 - 10-21-2012, 10:44 PM
Users browsing this thread: 14 Guest(s)
There are currently 3261 online users. [Complete List]
» 3 Member(s) | 3258 Guest(s)
