  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
Yes, I replaced the 1 MEG resistor when I rewired the eye tube socket. All of the original wires were pretty rough. Maybe I'm not getting too much action on the eye tube because I am only using a 2 foot piece of wire for the antenna right now?
What is the resistor number for the 47K you are mentioning? I checked all of the coil windings after I removed all the wiring and everything checked out OK.
- Geoff
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 10-21-2012, 11:57 PM
Users browsing this thread: 15 Guest(s)
There are currently 3463 online users. [Complete List]
» 1 Member(s) | 3462 Guest(s)
