Starting another Philco
I should have learned but like these radios, you might have seen the lovely 111 I had finished and the nice lady wanted back. Well had a space and this is what I'm starting on now. A Philco 90 single ended 47. It should take the place when the nice lady comes back to pick up the 111. I will be asking for some help, already ordered from Chuck the proper schematics and sent the 1st detector coil off to Ron. This one at least I could see some green on.
Hope you will help me on the restoration. Probably some questions on the cabinet forum and certainly a few on this. So far as I can see, both electrolytic caps have been replaced with well, things not right. I might have a donor chassis located with the right ones. Underneath, several parts hanging in the air. Appears a couple of block caps went South and were bypassed. More details to sort.
Well let's enjoy the journey.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...sistop.jpg]
[Image: http://i303.photobucket.com/albums/nn129...bottom.jpg]
[Image: http://i303.photobucket.com/albums/nn129...abinet.jpg]
[Image: http://i303.photobucket.com/albums/nn129...peaker.jpg]
Starting another Philco - by jerryhawthorne - 10-22-2012, 12:56 AM
RE: Starting another Philco - by TimC - 10-22-2012, 09:05 PM
RE: Starting another Philco - by gary rabbitt - 10-23-2012, 03:17 AM
RE: Starting another Philco - by jerryhawthorne - 10-23-2012, 01:13 PM
RE: Starting another Philco - by 7estatdef - 10-23-2012, 08:17 PM
RE: Starting another Philco - by jerryhawthorne - 10-23-2012, 09:53 PM
RE: Starting another Philco - by TA Forbes - 10-24-2012, 02:50 PM
RE: Starting another Philco - by jerryhawthorne - 10-25-2012, 06:13 PM
Philco 91 Tuning Condenser
