Another Coronado 2cm
I don't know if I want to replace the switch now.
Looks there were some wiring mods made and a couple caps removed and others put in different spots.
Might be opening up a can of worms.
I wish people would not jerry rig these old timers like that.
Makes it hard to work on later for the next guy.
I think I will just finish re-capping it and call it good.
Don't really need that function anyway.
Anyone know why Wells Gardner has that metal plate laying under the chassis?
Just sits under there and it looks like it has a ground terminal on it.
Both of my sets have it, and neither one is attached to anything.
Have a great day.
murf
Another Coronado 2cm - by murf - 10-18-2012, 10:16 PM
RE: Another Coronado 2cm - by TA Forbes - 10-18-2012, 11:39 PM
RE: Another Coronado 2cm - by murf - 10-19-2012, 06:59 AM
RE: Another Coronado 2cm - by murf - 10-19-2012, 08:45 PM
RE: Another Coronado 2cm - by TA Forbes - 10-20-2012, 12:04 AM
RE: Another Coronado 2cm - by murf - 10-23-2012, 10:34 PM
There are currently 9142 online users. [Complete List]
» 5 Member(s) | 9137 Guest(s)
AvatarAvatarAvatarAvatar
