  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
#34
I went ahead and measured the voltages. I used a digital multimeter for all the measurements. I had the radio plugged into my variac and the voltage going to the radio was 117.1 VAC. Here is what I got:
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=2]
I wasn't sure what "AC" meant so I measured both AC and DC voltage for those particular pins.
Could somebody with more experience take a look at these and let me know what you think. Some of the voltages seem a bit high. All capacitors and resistors were replaced.
Geoff
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 10-24-2012, 12:00 PM
There are currently 3427 online users. [Complete List]
» 1 Member(s) | 3426 Guest(s)
