resistors in bakelite caps
1/2 watt carbon or carbon film resistors are fine to re-stuff in combo bakelite block condensers. Small cardboard carded wire resistors were used for their smallness and low values made the bundle smallish as well.
A 270 ohm will be fine. Still well under the 20% tolerance of the older resistors.
resistors in bakelite caps - by Doug K. - 07-04-2007, 11:21 AM
[No subject] - by Chuck Schwark - 07-04-2007, 12:17 PM
[No subject] - by Doug K. - 07-04-2007, 11:28 PM
[No subject] - by Chuck Schwark - 07-05-2007, 08:51 AM
There are currently 6132 online users. [Complete List]
» 2 Member(s) | 6130 Guest(s)
