Tuning on Philco 46-200, 48-200
Testing the loop was for an OPEN, not shorts. If you measured only a couple ohms or less, then the loop is good. I assume your disconnected one end of the loop to isolate it before you tested it, otherwise results may be invalid due to connections in the radio.
Sounds like it may still be out of alignment then from your re-tweeking. I'd also test for continuity of the IFT's, both pri and sec windings.
Chuck
Tuning on Philco 46-200, 48-200 - by winkydink - 10-23-2012, 09:55 PM
RE: Tuning on Philco 46-200, 48-200 - by Arran - 10-24-2012, 07:19 PM
RE: Tuning on Philco 46-200, 48-200 - by Arran - 10-25-2012, 01:45 AM
RE: Tuning on Philco 46-200, 48-200 - by Arran - 10-25-2012, 05:12 PM
RE: Tuning on Philco 46-200, 48-200 - by Chuck Schwark - 10-26-2012, 09:48 AM
There are currently 10723 online users. [Complete List]
» 3 Member(s) | 10720 Guest(s)
