  • 1 Vote(s) - 5 Average
Philco 623 cabinet restoration
Those grill bars are bad for delaminating in things like this, but in Philcos in particular, in fact the ones in my 620 were broken and glued back together at least twice. The front panel on mine really needs to be re-veneered, not only to cover up the cracks in the grille bars but someone used a disk sander on it and left crescent shaped scratches and gouges all over it.
Philco 623 cabinet restoration - by Bob Andersen - 10-26-2012, 12:54 PM
RE: Philco 623 cabinet restoration - by Arran - 10-26-2012, 10:37 PM
RE: Philco 623 cabinet restoration - by TA Forbes - 10-26-2012, 11:21 PM
RE: Philco 623 cabinet restoration - by Arran - 10-31-2012, 06:29 PM
RE: Philco 623 cabinet restoration - by Arran - 11-02-2012, 06:57 PM
RE: Philco 623 cabinet restoration - by Arran - 11-03-2012, 12:03 AM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2576 online users. [Complete List]
» 2 Member(s) | 2574 Guest(s)
