  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
Mighty fine!! Icon_thumbup
RE: Growing up quick...with a 38-690xx Pics added. - by TA Forbes - 10-27-2012, 04:29 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
