  • 1 Vote(s) - 4 Average
Philco 37-116X What's The Price Point?
#49
Our house is large too, but most of our radios are displayed in our 2000 sq ft shop. THIS ONE goes in the living room because both my wife and I like it. In our opinion it is very nice looking and classic, one of Philco's best, both visually and electronically (pre-WW II). And, no, it is not all that hard to work on.
And it weighs too much to "rotate" vey often.
About 17 wires counting the ground.
RE: Philco 37-116X What's The Price Point? - by Phlogiston - 10-28-2012, 11:43 AM
Philco 91 Tuning Condenser
