Grunow 835 question
Hello fella's,
Well I tried the grunow on shortwave last night and it seemed to be working on all frequencies.
I was able to pull in some stations on am at the lower end of the dial, but they were not as loud and stong as on the upper half.
I found that there was a wire connecting the 2nd and 3rd gangs of the tuning condensor on the terminals on the top.
Wire was frayed and touching the condensor. One end of the wire was just pushed through the hole in the connector while the other end was soldered.
I removed the wire and tried it and it seemed to work better.
I will have to refer to the schenmatic and see if that wire is supposed to be there.
Not sure on how to check the condensor with an ohm meter?
Would you check the stationary fins to the hinged fins or what?
Anyway, have to go out and clean up leaves, so have a great weekend guy's.
murf
Grunow 835 question - by murf - 10-27-2012, 02:54 PM
RE: Grunow 835 question - by Steve Davis - 10-27-2012, 03:10 PM
RE: Grunow 835 question - by TA Forbes - 10-27-2012, 04:32 PM
RE: Grunow 835 question - by morzh - 10-27-2012, 04:40 PM
RE: Grunow 835 question - by Arran - 10-27-2012, 08:45 PM
RE: Grunow 835 question - by murf - 10-28-2012, 02:46 PM
RE: Grunow 835 question - by murf - 10-28-2012, 04:52 PM
RE: Grunow 835 question - by codefox1 - 10-28-2012, 06:58 PM
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3611 online users. [Complete List]
» 2 Member(s) | 3609 Guest(s)
