  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
That is some real fine looking work!!! Great job!!!
Gene
RE: Growing up quick...with a 38-690xx Pics added. - by Gene Pederson - 10-28-2012, 07:53 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
