  • 2 Vote(s) - 4 Average
Just got a model 90
Sourced a new escutcheon from Great Northern Antique Radios in Minneapolis. 20 bucks. Ordered it Friday, got it Monday. It is an exact match, cannot tell the new one and the original apart (aside from the broken corner). Happy Happy joy joy.
Just got a model 90 - by Groundhog74 - 10-25-2012, 08:37 PM
RE: Just got a model 90 - by TA Forbes - 10-25-2012, 08:40 PM
RE: Just got a model 90 - by Groundhog74 - 10-26-2012, 08:46 AM
RE: Just got a model 90 - by Groundhog74 - 10-30-2012, 06:46 AM
RE: Just got a model 90 - by Groundhog74 - 10-30-2012, 06:52 AM
RE: Just got a model 90 - by Chuck Schwark - 10-30-2012, 09:54 AM
RE: Just got a model 90 - by Groundhog74 - 10-31-2012, 06:13 AM
RE: Just got a model 90 - by jerryhawthorne - 10-31-2012, 09:31 PM
RE: Just got a model 90 - by Groundhog74 - 11-01-2012, 06:51 AM
RE: Just got a model 90 - by jerryhawthorne - 11-01-2012, 01:29 PM
RE: Just got a model 90 - by thirtiesradio - 11-08-2012, 01:56 AM
Philco 91 Tuning Condenser
There are currently 5368 online users. [Complete List]
» 1 Member(s) | 5367 Guest(s)
